Nouvelle restauration - Bruit suspect Emptypar yannick 63 Mar 30 Avr 2024 - 22:41
Nouvelle restauration - Bruit suspect Emptypar GeoDals Mar 30 Avr 2024 - 20:01
Nouvelle restauration - Bruit suspect Emptypar oustad Lun 29 Avr 2024 - 19:03
Nouvelle restauration - Bruit suspect Emptypar Pzc29 Lun 29 Avr 2024 - 10:33
Nouvelle restauration - Bruit suspect Emptypar ST44 Sam 27 Avr 2024 - 18:07
Nouvelle restauration - Bruit suspect Emptypar hdmanillac Ven 26 Avr 2024 - 19:21
Nouvelle restauration - Bruit suspect Emptypar meux Ven 26 Avr 2024 - 18:44
Nouvelle restauration - Bruit suspect Emptypar REYNALD Ven 26 Avr 2024 - 11:53
Nouvelle restauration - Bruit suspect Emptypar MB Mer 24 Avr 2024 - 21:40
Nouvelle restauration - Bruit suspect Emptypar Mer14 Mer 24 Avr 2024 - 10:42
Nouvelle restauration - Bruit suspect Emptypar aulo Mar 23 Avr 2024 - 13:54
Nouvelle restauration - Bruit suspect Emptypar yd64 Mar 23 Avr 2024 - 8:34
Nouvelle restauration - Bruit suspect Emptypar yop1025 Lun 22 Avr 2024 - 20:30
Nouvelle restauration - Bruit suspect Emptypar Buszost Ven 19 Avr 2024 - 22:56
Nouvelle restauration - Bruit suspect Emptypar Buszost Ven 19 Avr 2024 - 22:45
Nouvelle restauration - Bruit suspect Emptypar Chicken2525 Ven 19 Avr 2024 - 14:32
Nouvelle restauration - Bruit suspect Emptypar Johnparalot Mer 17 Avr 2024 - 21:44
Nouvelle restauration - Bruit suspect Emptypar jean-pierre 74 Mer 17 Avr 2024 - 10:43
Nouvelle restauration - Bruit suspect Emptypar Palex Mar 16 Avr 2024 - 22:33
Nouvelle restauration - Bruit suspect Emptypar thierry Mar 16 Avr 2024 - 7:14
Nouvelle restauration - Bruit suspect Emptypar aulo Mar 9 Avr 2024 - 13:09
Nouvelle restauration - Bruit suspect Emptypar Mer14 Mar 9 Avr 2024 - 9:09
Nouvelle restauration - Bruit suspect Emptypar Pandiwan Lun 8 Avr 2024 - 22:20
Nouvelle restauration - Bruit suspect Emptypar Ogugus Lun 8 Avr 2024 - 14:49
Nouvelle restauration - Bruit suspect Emptypar Borgil Lun 8 Avr 2024 - 14:07
manuel huile pneus fourche tuto carburateur phare tenere longues vidange embrayage filtre galére rabaissement synchro suis garde crash boue essence arrière réservoir reglage amortisseur chaine feux
coolstef
coolstef
Kms de ma moto : 14800
MessageSujet: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptySam 6 Fév 2021 - 17:05
Je restaure une nouvelle super ténéré pour un copain. Pas mal de boulot en perspective mais dans un premier temps, je tente de faire tourner le moulin pour un premier diagnostic. Le vendeur m’avait prévenu d’un bruit assez important dans le bas moteur, le prix était en conséquence…
J’ai vu que pas mal d’entre vous avaient un problème de ressort cassé dans la cloche d’embrayage, notamment l’ami Borgil qui a après pas mal de galères a fini par réparer sa mob.
Donc d’après la vidéo et le bruit, est-ce un ressort cassé ?
https://youtu.be/wRFHxOw4WIo
Borgil
Borgil
Kms de ma moto : 89000
Ville ou région : Grenoble
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptySam 6 Fév 2021 - 18:04
Ca y ressemble BEAUCOUP !
Pour rappel le bruit que moi j'avais à ce moment là :
https://www.youtube.com/watch?v=3f5Ow11crAU
PS : je t'ai envoyé un message privé Coolstef, si tu peux jeter un oeil ;)
benproof
benproof
Moto : XTZ 750 Super Ténéré
Kms de ma moto : 68000
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptySam 6 Fév 2021 - 21:47
Hello Borgil,
Je serais curieux de savoir le bruit de ton xtz desormais, si jamais tu as un peu de temps pour faire une video et la mettre en ligne? trosuper
Merci!
benproof
benproof
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptySam 6 Fév 2021 - 21:50
Parce que la Coolstef, le bruit suspect pour toi, ce serait le petit commeun ressort qui cliqueterais en fond sonore? car sinon j'entends rien de suspect de mon coté ?
coolstef
coolstef
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptySam 6 Fév 2021 - 23:21
Oui, mais en vrai, c’est plus qu’un cliquetis en fond sonore.
Je connais bien le bruit d’un moulin en forme et là tu te dis faut que je coupe avant de tout casser ;)
Borgil
Borgil
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptySam 6 Fév 2021 - 23:56
Honnêtement à part un joint à 12€ et 15min de ton temps, ça ne te prendra rien de plus pour vérifier !!!
Ne fais pas la même erreur que moi à passer un an en te disant que c'est autre chose, alors qu'un simple outil pour bloquer l'embrayage te permet de le démonter simplement et de vérifier si c'est ça...
Et même si ce n'est pas ça, un nouveau joint (je le rappel, à 12€ seulement) et 15min plus tard c'est remis comme avant.
coolstef
coolstef
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyLun 8 Fév 2021 - 14:49
Tu as raison Borgil, je vais commencer par ça.
Jamais démonté un embrayage, tu as une référence pour l'outil ?
Thibs
Thibs
Kms de ma moto : 80.000
Ville ou région : jurbise
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyLun 8 Fév 2021 - 19:11
Salut coolstef, perso je n'ai pas eu besoin d'outils specifique pour démonter, j'ai démonté le carter d'embrayage, retiré le plateau de pression et les disques.
Une fois arrivé sur la cloche, tu met la 5eme, tu appuies sur le frein arrière et tu desserre sans soucis avec un bras de levier correct (c'est même ce qui est conseillé dans la rmt de memoire ... Idem pour le remontage par contre table sur un poil plus de 15 min, c'est le temps qu'il m'a fallu pour nettoyer proprement le plan de joint 😅 mais rien decde compliqué en tout cas
Thibs
Thibs
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyLun 8 Fév 2021 - 19:16
Nouvelle restauration - Bruit suspect Img-2021
Nouvelle restauration - Bruit suspect Img-2022
coolstef
coolstef
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyLun 8 Fév 2021 - 20:56
OK, merci Thibs.
On voit bien le ressort HS mais tu as fait comment ensuite ?
Tu as changé toute la cloche ou seulement le ressort ? Dans ce dernier cas, le plateau est serti...
Même question à Borgil d'ailleurs qui n'a investi que 12€...
Thibs
Thibs
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyLun 8 Fév 2021 - 21:00
J'ai acheté un embrayage complet ( cloche + disques ) de tdm (premier modèle) sur boonstraparts pour 75 €.
J'ai changé uniquement la cloche et j'ai gardé les disques pour plus tard... C'est pour moi la seule solution fiable. Il y a également possibilité d acheter uniquement la cloche pour +- 50€ sur eBay.
Borgil a également changé la cloche au complet de mémoire , 12 € si tes ressorts sont bon = uniquement prix du joint je suppose.
Borgil
Borgil
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyMar 9 Fév 2021 - 9:35
12€ c'est la perte que tu aura d'avoir ouvert ton carter SI et seulement SI la cloche d'embrayage est en bon état.
Si par contre les ressorts sont HS comme pour Thibs, moi, ou 99% des propriétaires de XTZ 750, alors il te faudra :
- soit en sertir de nouveau (70€ le kit d'origine sur Wemoto, mais c'est les mêmes ressorts de m***e qu'en 1990 donc....inutile). Donc ça veut dire ouvrir la cloche, sertir les ressorts, refermer la cloche ==> long et couteux
- soit trouver un embrayage de TDM (3VD ou 4TX, les deux fonctionnent) et le mettre à la place du tiens
Moi j'ai clairement choisi la 2eme solution, car les ressors sont 2 fois plus épais / résistants, et que tu trouves des embrayages complets pour une soixantaine d'euros si tu as de la chance (moi j'ai trouvé sur "surplusmoto.com"). L'embrayage était tellement en meilleur état que j'ai TOUT remplacé : cloche, roulements, disques garnis ou non, etc...
Car oui, c'est du plug&play, les embrayages sont totalement interchangeable.
Donc comme dit :
- vérifie l'état de ta cloche
- si tout va bien tant mieux (mais j'en doute vu le bruit)
- si t'as un ou des ressorts pétés, bah cherche un embrayage complet ;)
coolstef
coolstef
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyMar 9 Fév 2021 - 10:03
Merci Borgil, c’est très clair 😏
Tu confirmes que les embrayages 4TX sont compatibles car j’ai commencé à regarder sur eBay et ils sont moins chers ?
Borgil
Borgil
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyMar 9 Fév 2021 - 15:03
Bah Surplumoto me l'a vendu en tant que 4TX oui.
benproof
benproof
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyMar 9 Fév 2021 - 21:07
Hello,
et celle la sur le site GN Moto :
https://www.gn-moto.com/12708/-cloche-embrayage-850-900-tdm-trx.html
Bon par contre il n'y a pas la noix d'embrayage et les disques...personne àencore testé je crois de laisser noix et disque de l'XTZ sur la cloche de TDM.
J'ai faillis le faire car je trouve l'embrayage de TDM plus dur mais j'ai pas encore franchis le pas.
Borgil
Borgil
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyMer 10 Fév 2021 - 9:34
benproof a écrit:
Hello,
Je confirme, embrayage du TDM obligé de prendre le levier à pleine main...c'est limite difficile sur un long feu rouge ^^
Par contre idem, j'ai vu plein de gens se demander si le changement seul de la cloche était faisable. Et au final, je n'ai jamais vu personne y répondre...
De ce que j'ai vu en ayant les 2 embrayages en main, chaque pièce est soit identique, soit interchangeable. Donc j'aurai tendance à dire que c'est jouable. Mais dans mon cas, l'embrayage -complet- de TDM que j'ai acheté était en meilleur état, donc j'ai pas cherché plus loin et j'ai tout installé d'un bloc
coolstef
coolstef
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyJeu 18 Mar 2021 - 17:35
Quelques nouvelles de ma restauration.
Le diagnostic du bruit moteur était juste : deux ressorts cassés sur la cloche d’embrayage qui se baladaient du côté de la couronne. J’ai pu tout récupérer à la pincette !
Coup de chance, sur un vieux moteur récupéré, la cloche avait être changée car les ressorts sont de meilleurs qualité (les 6 ressorts sont épais et non 3 sur 6).
Par contre, je galère un peu au remontage. Je pense que je remet mal le couvercle et la biellette sur laquelle se fixe le câble.
Du coup, c’est tout mou et visiblement, ça n’embraye pas...
Donc comment procéder pour que ça tire bien le plateau mobile ?
coolstef
coolstef
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyJeu 18 Mar 2021 - 17:36
Nouvelle restauration - Bruit suspect F2a9b810
Nouvelle restauration - Bruit suspect 9520ef10Nouvelle restauration - Bruit suspect F2a9b810
Thebestroll
Thebestroll
Ville ou région : Sarrebourg
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyJeu 18 Mar 2021 - 22:33
Salut, en fait il faut anticiper sur la rotation de la biellette du à l’engrenement du pignon de l’axe sur la crémaillère pendant l’insertion.
Et là tu saura dans quelle position engager l’axe pour qu'il soit là ou il faut quand le couvercle est en place.
Et si ça va pas tu sors, tu tournes l’axe et tu rentre à nouveau.
Tout doit être bien lubrifié
Suis- je clair ?
coolstef
coolstef
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyVen 19 Mar 2021 - 8:57
OK, c’est clair, merci ! Je vais essayer comme ça.
J’ai pas mal de jeu sur l’axe, est-ce normal ?
Du coup quand je positionne le couvercle, il faut qu’il soit tiré ou poussé ?
Borgil
Borgil
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyVen 19 Mar 2021 - 12:09
Personnellement, j'ai fait différemment.
J'ai fait en sorte que l'axe soit "à peu près" en face du trou du carter. Mais comme toi, l'embrayage était trop mou et ne tirait rien.
Du coup, j'ai déclipsé le système sur lequel on fixe le câble (le truc qui sort du carter par le haut), et l'ai fait avancer d'un ou deux cran sur son axe. Ca permet de régler finement la course de l'embrayage.
Par contre attention en faisant ça, le ressort essaiera de tout te faire sauter au visage ^^
Nouvelle restauration - Bruit suspect Carter10
Thebestroll
Thebestroll
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyVen 19 Mar 2021 - 17:22
Il faut que le point d’attache du câble sur le levier soit plus loin vers l’AR de la moto au moment où on commence à engrener. Pendant le rapprochement du carter le levier va revenir ver l’AV.
coolstef
coolstef
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyLun 22 Mar 2021 - 19:00
Bon, j'ai trouvé le temps de remonter tranquillement mon embrayage.
Effectivement, si on ne veut pas sortir l'axe, il faut il faut le tourner suffisamment vers la gauche au moment du positionnement du carter pour compenser le jeu, donc plus à gauche que ce que préconise la RMT qui dit d'aligner les deux repères.
J'ai donc changer changé la cloche qui avait deux ressorts cassés dont un qui se baladait. J'ai récupéré tous les bouts et remonté l'embrayage qui a priori fonctionne bien.
Mais j'ai toujours un bruit suspect... Dans la première vidéo (au début de mon post) ce bruit était sans doute confondu ou couvert avec le bruit provoqué par les bouts de ressorts de la cloche.
Dans la seconde vidéo ci-dessous, on entend bien ce cliquetis surtout à la fermeture des gaz.
Une idée de l'origine du bruit ? Est-ce encore lié à l'embrayage ou est-ce carrément autre chose ?
https://youtu.be/IWFkzhVuXQY
Thebestroll
Thebestroll
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyLun 22 Mar 2021 - 20:39
Petite fuite echappement en sortie de culasse?
Borgil
Borgil
MessageSujet: Re: Nouvelle restauration - Bruit suspect   Nouvelle restauration - Bruit suspect EmptyMar 23 Mar 2021 - 10:15
Ah oui là ... c'est pas jojo.
Absolument aucune idée de ce que ça peut être, mais c'est pas rassurant. La chaine est tendu normalement ? Il manque pas un guide ? Le réglage du jeu aux soupapes est bon ?
C'est tout du même côté que l'embrayage, donc...le bruit peut venir de tout et n'importe quoi ici :/
» RESTAURATION XTZ 660
» bruit suspect à chaud
» Bruit suspect avec un passager
» restauration 660 3YF
» Restauration 750 XTZ de 89.
